GP Giant Aeromaster
GP Giant Aeromaster
Post by kdoughty » Wed Oct 12, 2016 9:15 am
I purchased a Greatplanes Giant Aeromaster at a swap meet about 12 years ago for $100. I documented the build with pictures. The plane weighed about 18 LBS and was designed for 30 to 60 Gas engine. I originally put a US 41 cc Gas engine in it. I was not happy with the way it flew . It was only getting 14 LBS of thrust and Flew scale like. :roll: When the DL 50 came out I thought I would try it. What a difference. It puts out 28 LBS of thrust and weighted almost two pounds less, now it will hover and pull out straight up. :D Any way here are the pictures.
Re: GP Giant Aeromaster
Post by kdoughty » Thu Oct 13, 2016 10:50 am
Here's more pictures as work continues . :)
Post by kdoughty » Fri Oct 14, 2016 10:51 am
Here's more pictures :D
Notice the 1/4" balsa in the fuselage .No thin sheeting here!! Don't make them now , like now they did back then. :shock:
Post by kdoughty » Sat Oct 15, 2016 9:34 am
The work continues with more pictures.
Post by kdoughty » Sun Oct 16, 2016 10:01 am
More pictures as the work go on. :)
Post by kdoughty » Mon Oct 17, 2016 9:38 am
Ready for more?
Post by kdoughty » Tue Oct 18, 2016 10:07 am
Starting to look like a plane . Still a lot of sanding. 8-)
Post by kdoughty » Wed Oct 19, 2016 9:34 am
Now I can start putting it all together.
Post by kdoughty » Thu Oct 20, 2016 8:51 am
More pictures putting together.
Post by kdoughty » Fri Oct 21, 2016 9:44 am
Just about finished putting all together . Next is covering. :D
